Help Removing Left Valve Cover
Car: 87 T/A
Engine: 305 4BBL
Transmission: 700R
Help I can't get the driver side valve cover off my stock 1987 TransAm with 305 4BBL with A/C. I have moved the throttle bracket and brake booster line, and A/C support bar. It still doesn't have enough clearance between the A/C and the windshield motor assembly to come out. The book doesn't say anything about removing the A/C to get it off. Is there some trick to getting it off? I really don't want to lose my R12.
Re: Help Removing Left Valve Cover
The A/C compressor has to be dis-mounted. Not a big deal.
Just take the 3 adjustment bolts and the one pivot bolt out; unplug the electrical connections; and lift it up out of there and set it on top of the radiator.
No need to worry about the Freon. It'll stay in there.
Car: 87 T/A
Engine: 305 4BBL
Transmission: 700R
Thanks Sofakingdom, that worked perfectly.
Didn't look like it would come out like that with the lines attached but it did.
NBrehm
Aug 25, 2015 11:49 PM
