87 gta 350 tpi. oil blows out dip stick!!!!!!!!!
Old Mar 30, 2007 | 09:16 PM
gtatech's Avatar
i just rebuilt my 87 gta 350 tpi. new pistons bored .030.lingenfelter cam,shaved heads,mild porting,roller rockers,headers,.the problem is when it gets into the higer rpm it pumps oil out the dip stick tube. it doesn't apear to have any blow by.if i drive normal it's ok,if i start to beat it it blows oil out the dpstick tube. any help?
Old Mar 30, 2007 | 09:32 PM
jonmark1985's Avatar
Car: 89' Pontiac Firebird
Engine: L03 carb Ported #87s new shortblock
Axle/Gears: 2.73 open
Re: 87 gta 350 tpi. oil blows out dip stick!!!!!!!!!
did you hook up the pcv valve?
Old Mar 30, 2007 | 09:42 PM
gtatech's Avatar
yes the pvc is working. i did leave the stock breather on the other side, the one going into the throtle body
Old Mar 30, 2007 | 09:45 PM
can you hear the valve rattle when you shake it?
Old Mar 30, 2007 | 09:49 PM
gtatech's Avatar
yes, some guys are saying to get rid of the stock breather on the pass. side. and go with a open type. the ca causeing low vaccum and high crankcase pressure?
i ment to say the cam
Old Mar 30, 2007 | 09:56 PM
where you got the vaccum line for your crankcase hooked up to? and im not famaliar with tuned ports but it seems on most newer cars they don't use a breather on the valve cover, they'll actually suck air from a tube after the air filter
89GTAOz
May 16, 2020 09:31 AM
maroe624
Apr 16, 2017 08:29 AM
Navy8125
Aug 21, 2015 09:32 AM
st.evel07
Aug 13, 2015 06:15 PM
