SB2 heads
Old Mar 31, 2007 | 10:33 PM
CndypntZ's Avatar
SB2 heads
I'm building a 406 for my 89 rs I got the rotating assembly and all the machine work done to the block I'm thinking of buying a used set of sb2 heads to top it off besides the rockers and the intake are there any special parts that I'll need to make these heads work on my motor?
Old Apr 1, 2007 | 12:12 AM
Guest
Guest
Posts: n/a
Re: SB2 heads
The exhaust side is different too. I'd also venture a guess that with the wrong cam and pistons, piston-valve clearance may become an issue.
Old Apr 1, 2007 | 04:02 PM
Rob Wade's Avatar
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
Re: SB2 heads
Ya you will have to have a set of headers made. That will not be cheap. I usually charge between $800.00-1000.00 for a custom set of long tubes including the cost of the kit. Bank on a few bucks there.
Old Apr 1, 2007 | 04:04 PM
rgauder's Avatar
Car: 1987 Trans Am
Re: SB2 heads
Don't forget pushrods.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
