Rough idle
Old Apr 1, 2007 | 03:17 PM
eighty_nine_ta's Avatar
Car: 89 Firebird
Rough idle
My car has a really rough idle. It goes back and forth between about 500 and 800 sometimes lower almost to the point of dieing. Could new plugs/wires maybe help this?
Also, at high RPM's, about 4K, the engine sounds like it's trying to cut out. I'm replacing my fuel pump soon and I was wondering if that would help this.
Old Apr 1, 2007 | 04:31 PM
quadrojunk's Avatar
Re: Rough idle
First of all it might help to list anything you have checked, if any. I would check plugs/wires first, then check the fuel, it may just be a filter clogged. Thats not uncommon. Is this a daily driver or has it been sitting?
Old Apr 1, 2007 | 11:38 PM
Car: 89 Firebird
Re: Rough idle
It's a daily driver. I haven't really checked anything, I'm not too mechanically inclined. I changed the fuel filter a few months ago.
Old Apr 5, 2007 | 11:06 PM
raiders8498's Avatar
Car: 88 Trans Am
Re: Rough idle
im also having this problem but my cars been siting and before i parked it i pumped cheap gas i think it had water, and it went to the injectors and corroded it insise i already changed the filter does this make sense or could something else be the problem
Old Apr 6, 2007 | 07:09 AM
Blue-Z28's Avatar
Car: 86 IROC-Z
Engine: 305 tpi
Re: Rough idle
Is it a TPI-? Replace both MAF Relays, I had the same problem
https://www.thirdgen.org/forums/atta...n-z-relays.jpg
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
89fast5oh
Sep 8, 2015 09:55 AM
IROCtometal
Sep 2, 2015 02:01 PM
