stalling issues w/AC
Old Apr 2, 2007 | 07:54 PM
gordo420's Avatar
Car: 89 RS Camaro
Engine: 355ci.
Axle/Gears: 373:1
I have been searching for a few days now and can not come up with a ansear to why my car stalls whenever I turn the a/c on at about 20 or so seconds after I turn it on, I cleaned and reset the IAC for the sake of, but she can not idle at normal rpm's with a/c on without raising to 12-1300 which I know is way too much, I also checked ffor vacum leaks, but did not try it with a vac guage, with no a/c she runs good no issues whatsoever
By the way it is a new compresser and accumilator and oriface tube.
Old Apr 3, 2007 | 04:25 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
Re: stalling issues w/AC
If you have too much pressure in the A/C system it will make it stall. I had 450PSI on the high side and it was killing the engine. I lowered the pressure and now it isn't stalling. Check your pressure and see what it is.
jklein337
Sep 19, 2018 06:23 PM
TheTraut88
Sep 11, 2015 05:16 AM
TheTraut88
Sep 7, 2015 05:22 PM
greenyone
Sep 2, 2015 03:39 PM
Bryan F
Aug 18, 2015 02:28 PM
