Best quench?
Car: 1992 Z28
Axle/Gears: 10 bolt posi. G80
Best quench?
What have some of you guys found to be the best quench on a 350 with flat top pistons and fast burn heads, or any other heads? Does .035 sound good? Or can i go .030? Thanks!
Re: Best quench?
Closer is better, in general; but too close can be disastrous, if the pistons hits the head. I'll give up a HP or 2 if it means my motor doesn't mechanically self-destruct.
In the real world, .035 is about as close as you want to get. If you've got your block zero-decked THAT PERFECTLY to your pistons, I'd leave it alone and run it.
355tpipickup
Aug 27, 2015 08:13 AM
