86 Z28 runs bad when cold
Old Apr 4, 2007 | 12:02 AM
Payphonejesus's Avatar
Car: 1986 Camaro Z28
Engine: LG4 305
Axle/Gears: Richmond 3:73 Posi trac
I have a 1986 z28 camaro LG4 carbarated i have just instaled a new 02 sensor a new fuel pump a new Q jet carb with a new fuel filter new plugs wires cap rotor and when i first start it up it doesnt want to stay runing or idle and i know the choke is working properly and when i start it its about 80 degrees out side so its not like its cold out side and once its warm it idles fine right about 600 rpm and it will sit there and idle like that all day but when i first start it up it just wants to die till it gets to about 150 deg's any clue as what could be wrong im really starting to get frustrated
Old Apr 4, 2007 | 12:09 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: 86 Z28 runs bad when cold
It's the choke.
try these threads and see where it gets you;
https://www.thirdgen.org/forums/carb...ighlight=choke
Old Apr 4, 2007 | 12:13 AM
Engine: LG4 305
The choke would make it run bad even when its nice and warm out side i know the choke opens fully when warm ive checked that and im pretty sure its closed when cold
Old Apr 4, 2007 | 10:31 AM
cool84's Avatar
Car: 84 trans am
Transmission: built 700r4
even if its warm out the choke will still be engaged as soon as you start the car. its still takes a little time to warm up.
Old Apr 4, 2007 | 02:52 PM
Sonix's Avatar
Car: 1982 Trans-Am
You've gotta use punctuation, I have no idea what you just said.
If your car runs fine when hot, then the choke is the problem, period. Anytime the car is significantly below operating temperature, the choke is on, so warm or cold outside is irrelevant, the choke will go on when you first start the car.
It's probably set up wrong. Fast idle, or choke pulloff most likely. Did you check my links?
Frozer!!!
Jan 19, 2024 04:55 PM
jklein337
Sep 19, 2018 06:23 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
