Hood Clearance (heres a good one...)
Old Apr 5, 2007 | 11:40 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Just throwing this out there, hopefully someone has a similar setup...
Performer RPM airgap intake
Holley street avenger 770cfm
K&N X-stream assembly (std 9/16" raised base w/ 4" element)
Looking at purchasing a Harwood 4" Cowl bolt-on hood to tuck this under, this will also hopefully leave enough room for a small blower one day or a centrifugal blow-through setup.
Since the intake is .5" higher than my current one and i assume the carb is the same height as a 600cfm edelbrock (probably not, anyone got a measurement?) and this air cleaner is about 2.25" taller than the old one... I HOPE this would all fit in there!
Anyone with a similar rig?
Old Apr 6, 2007 | 12:22 AM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
Re: Hood Clearance (heres a good one...)
standard vic jr. - 5/8" shorter than RPM airgap
1" spacer
demon carb
14x3 X-stream 9/16" raised base
i have a home-made scoop that is about 2" high in the back and 3" high up front.. it barely fits under there.. a 4" cowl should work for you
Old Apr 6, 2007 | 12:38 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
Cool, i figured it should all fit in there nicely. But thats judging by the fact that the street avenger carb isnt too much taller than a 600cfm edelbrock!
I guess if it doesnt fit i could always replace the 4" element for a 3"....
Old Apr 6, 2007 | 01:12 AM
5678TA's Avatar
Car: 1984 Trans Am
thats always an option.. but if it allows, i would go big.. if the wingnut on my filter didnt barely clear the roof of my scoop, i would have a 4" filter..
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
LittleFranks
Aug 20, 2015 03:55 PM
ElPaleterro85
Aug 13, 2015 03:49 PM
bryan623
Aug 10, 2015 11:33 AM
