carb plate?
Old Apr 8, 2007 | 10:20 PM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
carb plate?
where can i find the carb plate or whatever it is called. they use it when they have a cowl. i have tbi with a cowl so i was hoping to use one
Old Apr 8, 2007 | 10:47 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: carb plate?
you dont need one they call it a TBI spacer and i am pretty sure the tbi will fit under a stock hood with one
Old Apr 8, 2007 | 11:12 PM
Re: carb plate?
i already have the cowl hood. i wanted one to seperate the cool air from the hot engine air
Old Apr 8, 2007 | 11:20 PM
Car: 91 RS
Engine: 350 vortec
Re: carb plate?
well that would be a cold air intake or a ram air hood...
Old Apr 9, 2007 | 12:38 AM
Re: carb plate?
this is what i am talking about. something to block off the air filter.
Old Apr 9, 2007 | 11:29 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: carb plate?
Yea, those aren't really made you have to make it yourself. Not sure if there's a specific word for it, but search on this board on "sealing cowl" or something like that. You just want to seal your air cleaner to your cowl hood.
Some sheet metal and some tall rubber coated spongy foam and you're set.
Old Apr 9, 2007 | 11:53 AM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
Re: carb plate?
i was gonna do something like that to seal my filter to the scoop i have.. then i figure, i'll be getting a fiberglass 4incher later so it will be a waste.. unless i sell my hood and filter together.. hahaha like anyone would buy my cheap piece of fecal matter hood.. but like sonix said, you dont just buy something like that.. you have to make it..
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
devilschariot
Feb 25, 2016 03:08 AM
Wylecoyote08
Sep 8, 2015 08:26 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
