New Vacuum Diagram
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
New Vacuum Diagram
I am currently remaking the Vacuum Diagrams for our cars as a for fun project. It started with me remaking the diagram for my car so i could identify what went where easier and now I'm gonna try to redo all of them.
first the 4 bangers and a V6
82-84 2.5L TBI
85-86 2.5L TBI
86-89 2.8L MPFI
82-84 2.5L TBI
85-86 2.5L TBI
86-89 2.8L MPFI
Engine: 2.8 MFI
Re: New Vacuum Diagram
V6's
82 2.8L carbed
83 2.8L carbed
84 2.8L carbed
82 2.8L carbed
83 2.8L carbed
84 2.8L carbed
Engine: 2.8 MFI
V8's
85-86 5.0L TPI
87-89 5.0L-5.7L TPI
85-86 5.0L TPI
87-89 5.0L-5.7L TPI
Car: 86 Iroc Z28
Engine: 350 5.7L (rebuilding now)
Transmission: 700R4 shift kit
Axle/Gears: 3.73, 9-Bolt, stock posi
If you have one for a 86/87 TPI that would be great. It's an 86 car but with an 87 engine, 5.7L V8 TPI
Thanks,
Pat
Thanks,
Pat
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
would be nice if someone made hose/vacuum diagram for my 1986 tpi cruise control. got hoses all over tryign to put it back together from previus owner mess up.
Engine: 2.8 MFI
i updated the diagram for that motor.
I'm working on what I believe is an '88 5.7 TPI setup. I only see 2 vacuum ports on the throttle body. the small one on the bottom and one large on e on the side that goes to the passenger side valve cover. any one have a pic of where the other line connects that is shown?
Engine: 2.8 MFI
if your talking about the HVAC And CC hoses they may have a T and share the same source like my car does.
If people that have these motors that are hooked up correctly will let me know i will add that info. Kinda hard to be shure when i dont have one of each of these motors myself LOL.
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
I have an 89 Camaro LO3 305 TBI with Cruise. Most appreciate it. I am taking out my smog pump, diverter valve. Thanks much.
Here's one for some year of L69; I forget which one. Not that it matters since they're all the same AFAIK. And, the LG4s are all just like this too, except for teh air cleaner details.
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
They aren't all quite the same. This one doens't have the lines that go to the throttle servo and down to the ball looking thing that's stashed on the bottom of my driver-side fender. At least not that I can tell.
No; those are accessories, parts of whole other systems (A/C & cruise), not part of the engine. That's a copy of the emissions label, which is independent of what options the car was equipped with.
They get fed from a fitting on the top of the intake behind the carb.
Car: 1984 Trans Am
Car: 1984 Trans Am
What do you need for an 84 Carb? I've got a 84 T/A that's carbed. Let me know what your looking for and I'll try and help. Sorry, I don't have an accurate diagram for the accessories, just going off memory. The Camaro and T/A set up should be almost identical.
That's going to depend on the line you need. There should be about 4 different sizes depending on the accessory or engine part that it's going to.
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Another one that is quite hard to find is the diagram for 85 MPFI. It is a one off year.
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
where does the vacuum line that is located behind my tbi,but in front of my distributor run to?it comes right out of the intake.
To various accessories that aren't part of the engine.... cruise control, and the HVAC control system.
Same as any other L03....
The cruise and AC are part of the car, not the engine. Kind of like, your house builder might have given you a wiring diagram of your house; you won't however, find the schematic of the toaster in your kitchen, on the schematic the builder gave you. The toaster is a separate system from the house, even though it gets its power from the house wiring. Engine vacuum diagrams are usually like that: they tell you about the ENGINE, but then, you need a SEPARATE diagram for any accessory sub-systems that happen to hook up to the engine and use vacuum as one of their power sources.
Post one. Contribute, instead of complaining in all-caps that no one else has done what you want for you.
Engine: 2.8 MFI
wow i forgot all about this little project. thing was at the time i was doing it no one seemed to care. LOL. but ill make some more if yall want. and please even if you dont need the diagram but have the corresponding motor look them over and see if i have any mistakes.
man this is thread is OLD.
Oh and i want to add the various accessories to the diagrams.
man this is thread is OLD.Oh and i want to add the various accessories to the diagrams.
Car: 1989 TransAm GTA
Transmission: 700R
I am new to the thirdgen site but am definitely lovin' it! I have been searching for a vacuum diagram. Thanks for the work on a VERY NICE diagram for my 89 TPI!
Car: '83 z/28
Axle/Gears: Stock?
Hi, this is great.
I am currently putting my 91 L98 t/a back together, and cant figure out what connecter? plugs into the back of the egr solenoid. it looks like a vacuum line would connect to it.
It would be nice if the diagrams included the alpha codes, like this 1984 carbed 305:
So that owners could positively identify their diagrams.
This is another diagram for a 1984 carbed 305, but there are significant differences:
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
Just what I was looking for, great job BTW.
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
Car: 89 and 91 Camaro Convertibles
Engine: 305 and 350
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
