Years for electronic speedo?
Old Apr 10, 2007 | 12:56 AM
Alphius's Avatar
Car: '84 Z28
Engine: '02 LS1
Transmission: '02 T56
Axle/Gears: LS1 10-bolt 3.73 w/Auburn Pro
What years did the Camaro and Firebird switch from a cable-driven speedo to a VSS-driven one? I know the Firebird was earlier, but I can't remember the exact years. For the Camaro, was it when they switched the dash layout to the new style? Or was it earlier?
Old Apr 10, 2007 | 05:26 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Years for electronic speedo?
Originally Posted by Alphius
What year did the Camaro switch from a cable-driven speedo to a VSS-driven one?
1990.
JamesC
Old Apr 10, 2007 | 06:06 AM
jtrescot's Avatar
Car: 88 GTA
Engine: 355
Transmission: TH350
Axle/Gears: 3.42 Auburn Pro
When did the Firebird switch? I have an 88 someone swapped in a TH350 before I bought it. I can't find the cable or any wires.
Old Apr 10, 2007 | 06:12 AM
JamesC's Avatar
I "believe" the electonic speedos in Firebirds started in 86 (but I'm a Camaro guy).
JamesC
Old Apr 10, 2007 | 08:13 AM
Alphius's Avatar
Car: '84 Z28
Engine: '02 LS1
Thanks JamesC
Old Apr 10, 2007 | 08:25 AM
jtrescot's Avatar
Car: 88 GTA
Engine: 355
Transmission: TH350
Assuming my 88 Trans Am should have an electric one, I need to find the wire. Does anyone know what color(s), and also if it was routed down from the firewall or somewhere else? What parts do I need for the transmission to send it a signal?
Old Apr 10, 2007 | 10:48 AM
Guest
Guest
Posts: n/a
Yes, it was 1986 for the birds. Dont know wire color, but its going to run from the speedo to the VSS buffer attached to the bracket for the ECM on the passenger side. I cant remember if the wiring from the VSS on the trans goes through the tunnel or joins the engine wiring harness.
Old Apr 10, 2007 | 11:07 AM
jtrescot's Avatar
Car: 88 GTA
Engine: 355
Transmission: TH350
I can't be the first one to go through this, switching to a carbed engine and TH350. I will do a search. Thanks.
Fast355
Dec 2, 2016 06:33 PM
stickychinsac
Aug 31, 2015 06:06 AM
IROCZDAVE (88-L98)
Aug 24, 2015 06:54 AM
beachrodder
Aug 7, 2015 04:27 PM
