Basic tune help
Old Apr 14, 2007 | 03:36 PM
89jim's Avatar
Basic tune help
I need to do a basic tune on my 89 gta. I have new everything for the most part. Engine is a 383 now. I started it and ran it up to temp. And then shut it off to cool back down and look everything over. Over all it runs OK but there are a few problems. Car is idling at about 1200 rpms. If you crack the throttle after the car is warmed up it pops then revs. How do I make base adjustments . I tried to set the timing at 6 degrees . Is the wire you unplug to set the timing the same one which drives the tach ? Where do I start ?
Old Apr 14, 2007 | 06:55 PM
fire350tpi's Avatar
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
Re: Basic tune help
no no no, the one u wanna unplug is the one on the passenger side of the firewall, tan with a black tracer that cuts the ecm out of the loop
do this after the engine is running, then set base timing and shut of and replug in
sammy52401
Nov 11, 2015 07:20 PM
bigjay89gta
Oct 15, 2015 08:04 AM
loud91rs
Oct 5, 2015 10:05 PM
SRKLEGIN
Sep 30, 2015 07:19 PM
