gear drive with hydraulic lifters??
Old Apr 13, 2007 | 10:22 PM
dirtye30's Avatar
Car: 89rs
Engine: 350 tbi
Transmission: stock
why does the summit site say you cant use a gear drive with factory equipped hyraulic rollers?
Old Apr 13, 2007 | 10:28 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: gear drive with hydraulic lifters??
It won't bolt to the cam.
Old Apr 13, 2007 | 10:31 PM
dirtye30's Avatar
Car: 89rs
Engine: 350 tbi
Transmission: stock
are there any gear drives made for a hydraulic application?
Old Apr 13, 2007 | 10:37 PM
Guest
Guest
Posts: n/a
Pete Jackson.
Old Apr 13, 2007 | 10:38 PM
dirtye30's Avatar
Car: 89rs
Engine: 350 tbi
Transmission: stock
Originally Posted by madmax
Pete Jackson.
not any that i saw.... link?
EDIT: found it thanks!
Old Apr 13, 2007 | 10:41 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The hydraulic part has nothing to do with it. It's the bolt pattern on the factory roller cam.
Old Apr 13, 2007 | 10:44 PM
dirtye30's Avatar
Car: 89rs
Engine: 350 tbi
Transmission: stock
what if i buy a cam that isnt factory?
Old Apr 14, 2007 | 12:30 AM
Guest
Guest
Posts: n/a
If you buy any cam designed to work with the factory roller cam parts and put it in a factory roller cam block, get the gear for the factory roller cam setup.
Old Apr 14, 2007 | 07:40 AM
dirtye30's Avatar
Car: 89rs
Engine: 350 tbi
Transmission: stock
and if i go with a solid cam and lifter setup i can use the regular pete jackson? any problems going from hydraulic to solid?
Old Apr 14, 2007 | 07:48 AM
Pat Hall's Avatar
There are several manufacturers that make gear drives for the factory roller cams. Probably the reason that Summit doesn't say any of them are applicable is the fact that the noise a gear drive unit creates sets off the knock sensor on a stock, computer controlled motor. Pete Jackson makes a "quiet" version of their gear drive that supposedly doesn't affect the knock sensor. I run a normal, noisy gear drive on my old school 350 in my 69 Camaro, and I love it, but when I built my L98 350, I didn't want to worry about whether it would affect the knock sensor or not, so I just ended up going with a Cloyes True Roller timing chain set instead. The Cloyes set is more than adequate for any hot street small block engine. If you're set on a gear drive, just make sure the application is for 87-up with factory roller cam, and try to get the "quiet version".
Old Apr 14, 2007 | 07:34 PM
dirtye30's Avatar
Car: 89rs
Engine: 350 tbi
Transmission: stock
well the car is going to have an engine built for it so it doesnt really matter about the knock sensor as its not going to be there.
jklein337
Sep 19, 2018 06:23 PM
jharrison5
Aug 19, 2015 05:53 PM
86White_T/A305
Aug 17, 2015 12:16 AM
rsrmoore
Aug 7, 2015 08:44 PM
