062 valve stem lock grinding...
Old Apr 15, 2007 | 11:19 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
okay i have taken a look at my 062s and it appears that the valve stem seals arent pressed in all the way... tricky to get a picture of but just wondering how high they should be?
and what problems could i run into by grinding the bottom of the locks to allow for a cam with .510 lift? 062 valve stem lock grinding...-goodthingtheresa1gigcardinit.jpg
Old Apr 16, 2007 | 01:06 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: 062 valve stem lock grinding...
I know vortecs have the fat guide boss, but they use the positive valve seals factory don't they? I can't tell if they're far enough down from that picture, even though it is a fantastic high res picture, i'm impressed. I'm sick of camera phone pictures.
I wouldn't grind the valve locks, those are so weeny. (and do you mean locks or retainers?)
Either way, i'd grind the valve boss first.
Old Apr 16, 2007 | 01:22 PM
Car: 91 RS
Engine: 350 vortec
they are the positive seals from factory but could i actually grind down the boss? i havent played with positive seals before? well i thought the locks would hit before the retainers? hard to see without takeing one apart i guess...
db057
Apr 28, 2019 07:45 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Nick McCardle
Sep 10, 2015 08:36 PM
scottmoyer
Sep 7, 2015 07:06 PM
