Idle problem
Old Apr 16, 2007 | 06:08 PM
D BERRY's Avatar
Car: 89 Camaro RS
Engine: LO3
Axle/Gears: 273 pegleg
Idle problem
Have an idling problem, which I think is two parts. The car is a 89 Camaro with a L03 with a TBI, I just got this car and don't really know where I'm starting from in relation to mods. It does have headers and TBI mods. First the idle is too fast when first started, about 2000 to 2500, but of course the tach reads fast but it is idling faster than it should. Second once it's warmed up it idles at 950 but the idle speeds up every 6 seconds to 1100 for about a second and a half. Then drops back to 950, this is in neutral, in gear both readings are about 200 RPMs lower. Car seems to run pretty good otherwise.
Dave B
Old Apr 16, 2007 | 10:17 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: Idle problem
i would say to check the TPS and look for vacuum leaks
Old Apr 17, 2007 | 09:09 AM
D BERRY's Avatar
Car: 89 Camaro RS
Engine: LO3
Re: Idle problem
Thanks for the reply, I forgot to mention that the car is running rich too although I'm not sure if the problems are related. Vaccum could certainly be the problem with the high idle and I'll check the TPS. I'm so new to fuel injection that I have to consult my cheat sheet to find out what TPS stands for.
Dave B
Old Apr 17, 2007 | 03:30 PM
Car: 91 RS
Engine: 350 vortec
Re: Idle problem
if it is running rich then vacuum wouldnt be your problem but pull a plug and check
Old Apr 17, 2007 | 05:32 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Re: Idle problem
TPS- Throttle Position Sensor.
Old Apr 17, 2007 | 06:21 PM
D BERRY's Avatar
Car: 89 Camaro RS
Engine: LO3
Re: Idle problem
It's definatly running rich, the plugs were powdery black when I changed them, same for the O2 sensor, plus you can smell it. Yea I know TPS is throttle position sensor cause I have a diagram that I printed off the AutoZone site that shows all the goodies and thier location under the hood. Even though they don't seem to know anything their site does have some useful information.
Dave B
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
zeitghaist
Aug 18, 2015 07:33 AM
perZ
Aug 15, 2015 01:17 PM
