Oil up under oil fill cap
Old Apr 18, 2007 | 10:02 PM
goldens98's Avatar
My car has been smoking blue smoke. What I wanted to know was is it normal for some oil to be on top of the heads when you cut the engine off. It's like a puddle of oil by the springs it not overflowing or anything. Do you think the drain holes may be sludged up.
Old Apr 18, 2007 | 10:11 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Re: Oil up under oil fill cap
Yes, oil will pool a bit in the heads. Not much though, if its draining properly you should only see a bit pooling at the lower side of the head, it shouldnt be 1/2" deep right across!
83 Crossfire TA
Jan 3, 2016 01:26 PM
toronto formula
Nov 10, 2015 06:17 AM
gixxer92
Sep 1, 2015 04:32 PM
Navy8125
Aug 21, 2015 09:32 AM
