Can I run a 3 wire like a one wire?
Old Apr 19, 2007 | 09:28 PM
FIRECHICKEN's Avatar
Car: '89 Formula 350
Engine: 5.7L L98 TPI
Transmission: 700-R4 Automatic
Axle/Gears: 7.5 disc posi 3.23
I need to replace the O2 sensor in my car now!!! I would like to go with a 3 wire setup for the upcoming header install. I am not ready to wire it up though. I don't wanna buy two sensors though. I would like to buy a three wire O2 sensor but only hook up the sensor wire. I need to know if this will work like the factory setup and read correctly or will it just **** me off and not run right? I can't wire the other two wires yet cause I have not determined where I wanna install the sensor.
Also, where is a good spot to hook up a 12V source? I assume the ground will bolt to the back of the head like the adapter harnesses you can buy state to do??
Thanks for the help in advance
Old Apr 20, 2007 | 05:48 PM
Fullsizewagon's Avatar
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
Re: Can I run a 3 wire like a one wire?
In theory, yes, but of course there can be small differences just like there is between different brands of 1-wire sensors.
But what's the problem with wiring up an intermediate supply for it? If you are able to do wiring properly then you should be able to do it in a reversable manner and redo it later if neccessary. I'd just hook it up to one of the pink/black wires in the bay. Ground to head should be ok.
Please note that I don't have actual first-hand experience in using a 3- as a 1-.
Old Apr 20, 2007 | 07:57 PM
Damon's Avatar
Yes, you can. A 3-wire is just a 1-wire with a heater built into it. I have used 3-wire sensors from a 92 Vette in F-bodies running headers a couple times. The white wire goes to your current knock sensor wire in the wiring harness, just like stock. The two black wires are for 12V+ and a ground. It doesn't matter which is hooked up to which. It's just an electric resistance heater and polarity doesn't matter. And yes, it'll work without the heater wires hooked up at all- but you'll be basically turning your (more expensive) 3-wire O2 back into a 1-wire.
Old Apr 21, 2007 | 10:48 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Old Apr 21, 2007 | 11:05 AM
Damon's Avatar
Sorry- O2 sensor wire, not knock sensor wire. I was a little tired when I typed that.
eightsixseven
Dec 16, 2024 01:50 PM
midge54
Dec 27, 2019 04:14 PM
camaro11j
Sep 19, 2018 08:49 AM
Caspar
Jun 19, 2016 11:19 PM
