Questions about replacing valve seals
Old Apr 22, 2007 | 12:08 PM
trumps2000's Avatar
Car: 1985 Z28
Transmission: T-5 5 Spd
Axle/Gears: Built 10bolt w/3.73s
I'm replacing my valvetrain with a Comp Cams kit and I have a couple of questions. First off I've tore it down to fix my disappearing oil problem:
https://www.thirdgen.org/forums/tech...rough-pcv.html
I think I narrowed it down to an intake gasket leak (I'm going to install the new one with RTV around the intake ports), and/or leaky valve seals. Is there anyway to tell if the valve seal is bad by looking at it? After removing the #6 springs I've noticed a coating of oil on the valve stem after pushing it down and back up.
I'm following Aperion's instructions found here:
https://www.thirdgen.org/forums/tpi/...ive+valve+seal
I'm trying to remove the old seals, and they seem stubborn to come off. I've had to use a screwdriver to get'm off, but it leaves a bunch of crud behind. Whats the best way to remove them? I bought the new Felpro Positive seals, but I can't figure out where the o-ring goes or if I even need it. Aperion's valve stem has two grooves, mine has only one.
Also not sure if its a problem but when I spun the intake valve in its seat by hand, I can hear and feel a little bit of friction. The exhaust valve is smooth when spun. Is this good/bad/doesn't matter?
Old Apr 22, 2007 | 02:48 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Questions about replacing valve seals
For as cheap as valve seals are, don't worry about trying to figure out if they're still good or not, just replace them. Use a pair of pliers to grab them and twist them back and forth as you pull them off.
Old Apr 22, 2007 | 03:32 PM
trumps2000's Avatar
Car: 1985 Z28
I went out and got some brass wire brushes to clean up anything loose. As for the actual seals I bought the part you recommended in that thread, but it doesn't fit. The boss is too wide for the seal. Guess I'll have to go back to the auto part store tomorrow to try to find the right ones.
Old Apr 25, 2007 | 11:11 AM
trumps2000's Avatar
Car: 1985 Z28
Ok I'm an idiot. I mistook the metal shell underneath as a part of the head, and was wondering why nothing would work for me.
After realizing that, replacement was a cinch.
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
NBrehm
Aug 25, 2015 11:49 PM
redmaroz
Aug 16, 2015 11:40 PM
Exxon Limited
Aug 9, 2015 08:13 PM
Leggman1
Aug 6, 2015 04:15 AM
