does this sound like the lifters or wtf is this?
Old Apr 22, 2007 | 12:10 PM
Savaged's Avatar
http://s2.photobucket.com/albums/y26...ent=MOV034.flv
what do you think this ticking sound is?
Old Apr 22, 2007 | 12:20 PM
1989formula355's Avatar
Car: 89 formula, 89 Cadillac Brougham
Engine: 355,HSR,patriot alum. heads,TFS cam
Transmission: 700r4, 2500 B&M stall, shift kit
Axle/Gears: 3.73 ten bolt, powertrax locker
Re: does this sound like the lifters or wtf is this?
sounds like an exhaust leak
Old Apr 22, 2007 | 12:28 PM
Savaged's Avatar
na im pretty sure its not that. its definately coming from somewhere in the engine internally
Old Apr 22, 2007 | 12:34 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
I`ve had exhaust leaks sound like my engine was dieing.Sounded like I blew the moter but it was only the gasket in the collecter.
Old Apr 22, 2007 | 04:53 PM
Savaged's Avatar
alright thanks, ill be sure to take a closer look at it and see if i cant figure it out
Old Apr 22, 2007 | 07:22 PM
Angelis83LT's Avatar
Car: '83 Berli, '84 Berli, '84 Z28 HO
Engine: L69, LG4, L69
Transmission: TH700-R4, TH700-R4, T-5
Axle/Gears: 3.08, 3.08, 3.73 Posi
It does sound like a lifter. with the exaust leak one would expect that when he reved it the exaust leak to speed up as well. Wit the ticking going completely away on a rev, I would think that one of the lifters is not getting the oil it needs at the low rpms. I have experienced that and had 2 lifters that were toast.. better question is when you have that tick that sounds like an exaust leak but when you forget to plug the #7 cyl ignition in it goes away......
Old Apr 23, 2007 | 01:12 AM
Savaged's Avatar
#7 cyl? its a v6. but lifter is what i was thinking, which works out good cause theres a 2.8l bird at the junkyard i might be able to get some cheap lifters
Old Apr 23, 2007 | 03:06 AM
Yea I know it was a v-6. I had the same sound on mine and it is a v-8 Only ting is my sound goes away when there is no ignition in #7 perhaps you have an odd missfire or one of the lifters has gave on you. just sayin.
Old Apr 23, 2007 | 04:15 AM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
Although it sounds like a light tapping noise, that could be a rod knock too. Notice it went away at high rpm until it started to come back down too. Mine did that when I had a rod knock.
Old Apr 23, 2007 | 05:31 AM
Stevo's Avatar
Car: Pair of 92 Z28s
Sounds just like the loud tapping on my gf's car...so will these lifters come out with a magnet? If not how much work is it to get em out?
Very similar to my thread a few pages down, ill get a video for you to listen.
Old Apr 23, 2007 | 06:01 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Lifter tap wouldnt be that fast would it? A lifter would only move every other revolution. I had a mysterious lifter tap in my L03 for like a month and it went away for whatever reason, good or bad, but it was nowhere near that fast.
Old Apr 24, 2007 | 12:18 AM
Savaged's Avatar
when i get the money to do ANYTHING with the car im gunna do a basic tune up with fan belts, hoses, plugs, fluids, etc. see if that helps at all, if not i might just take it to a mechanic... a couple of my friends dads are mechanics so i should be able to get a deal
Old Apr 24, 2007 | 12:46 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Exhaust leaks are COMMONLY mistaken for cam/lifter problems. If you haven't done anything to the motor it's pretty rare for a hydraulic lifter to just up and fail on its own.
I'm really curious, because i'm bad at diagnosing mystery idling tapping noises. I have one, and i'm pretty sure it's my loose collector bolts... Be sure to post back when you do find the problem and fix it.
Old Apr 24, 2007 | 12:48 AM
Car: 1992 Camaro RS
Unless the 2.8s were using roller lifters, I'd recommend against that.
Even if they are using roller lifters I'd avoid it...
Old Apr 24, 2007 | 12:56 AM
Savaged's Avatar
i sure will. although my hours got cut back and im facing a money crisis right now... the whole bird project is on hold for the time being. when i do find out ill be sure to let you all know though, and hopefully this will help someone else with the problem
Old Apr 24, 2007 | 12:36 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
VIDEO
That's my old 305. Guess what happened to it three days later.Take a look.
Old Apr 24, 2007 | 05:47 PM
Savaged's Avatar
wow how...motivating. thanks token lol. i sure hope that isnt my problem
Old Apr 24, 2007 | 08:24 PM
Stevo's Avatar
Ditto. My tap was an exhaust leak.
Old Apr 24, 2007 | 08:52 PM
7.0 camaro's Avatar
Car: camaro
Engine: 383
Transmission: 350 turbo
change the oil and try a thicker oil. see if it changes it. i had a s-10 that sounded like that. i believe the shortblocks the same as yours. if i put 5-30 in it it tapped like hell. i put 20-50 in it. it went away. it's cheaper than tearing down the valvtrain. or pulling the oil pan.
Old Apr 24, 2007 | 08:53 PM
Savaged's Avatar
ok ill try that, thanks alot. seems alot easier that way
tmellott89
Oct 14, 2015 02:06 PM
wanext
Oct 6, 2015 12:18 AM
skinny z
Oct 5, 2015 06:23 PM
gord327
Sep 29, 2015 10:18 PM
