Speedo dosn't work after motor swap
Old Apr 22, 2007 | 07:23 PM
90TSiAWD's Avatar
Car: '91
Engine: 3.1 V6
Axle/Gears: Unknown
hey, I just finished putting a 350 Carbed into my 87 Formula it was orignally a 305 with a T-5 but when I got the car the 305 was long gone, so I put a motor in it and the speedometer and the instrument cluster lights do not work, the dummy lights and all the other gauges do.
Anybody have ideas? Ive been reading about the VSS going throught the ECM does my cars speedo go through the ECM?
Old Apr 22, 2007 | 07:27 PM
Angelis83LT's Avatar
Car: '83 Berli, '84 Berli, '84 Z28 HO
Engine: L69, LG4, L69
Transmission: TH700-R4, TH700-R4, T-5
Axle/Gears: 3.08, 3.08, 3.73 Posi
Re: Speedo dosn't work after motor swap
Yea I said something stupid.. Ha. happens. I reread it. I would say it is probably a ground was knocked off somewhere. Since the speedo or the ECM would have no bearing on the cluster lights, and with the speedo being electronic, maybe they share a ground.,
Last edited by Angelis83LT; Apr 22, 2007 at 11:43 PM. Reason: said something stupid. now more logical.
Old Apr 22, 2007 | 08:24 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
one question... what would a TPS sensor have anything to do with a speedometer?
Old Apr 22, 2007 | 09:31 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
not a bloody thing....
The speedometer on that should have been electronic. Trace the wires from the VSS at the tranny and check for any breaks in the wire along the way.
I cannot remember for sure if the speedo goes through the ECM or not, something tells me it did...
Old Apr 23, 2007 | 06:21 PM
90TSiAWD's Avatar
Car: '91
Engine: 3.1 V6
Axle/Gears: Unknown
Well I dont think I ever hooked up the body ground would that effect it?
Old Apr 23, 2007 | 07:08 PM
possibly? I am not sure, I do know that unless you hook up every ground odd things can happen.
Old Apr 23, 2007 | 07:56 PM
90TSiAWD's Avatar
Car: '91
Engine: 3.1 V6
Axle/Gears: Unknown
Well I just put in a new 140 Speedo and its stil doing the same thing all the dummy lights work and all gauges except speedometer and the cluster lights.
I'll try the ground tommorow its getting dark out.
Old Apr 24, 2007 | 08:58 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
Yes, give the ground a shot...
Bad grounds cause some pretty wacky stuff!
Old Apr 24, 2007 | 06:49 PM
90TSiAWD's Avatar
Car: '91
Engine: 3.1 V6
Axle/Gears: Unknown
Well I hooked the ground up and nothing, but I found my problem I tracked the VSS wires the purple and yellow one into my car and found that they are not connected any body know wheres these connect at inside your car?
Old Apr 24, 2007 | 07:52 PM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
http://www.hioutput.com/tech/speedo.html
this should help you out
Frozer!!!
Jan 19, 2024 04:55 PM
Jorlain
Aug 24, 2022 05:11 PM
st.evel07
Aug 13, 2015 06:15 PM
Irocohio
Aug 12, 2015 08:03 AM
beachrodder
Aug 7, 2015 04:27 PM
