Tpi to Carb, will AC work
Old Apr 22, 2007 | 09:51 PM
F-BOMB's Avatar
I have a 1985 iroc Tpi. I put in a 383 and plan to go carb. WIll I still be able to hook up the AC. I am not sure if the computer kicks it on or what?
Old Apr 22, 2007 | 09:55 PM
johnnyboy's Avatar
Car: '82 formula clone, 95 saab 900se
Engine: 350 vortec'd tbi, 2.0L turbo
Transmission: 700r4, 5 spd
Axle/Gears: 10 bolt 2.77 open
Re: Tpi to Carb, will AC work
ac isn't controlled by the computer, as long as you still have your compressor on the belt it should still work. if you didn't touch any of the ac system before you started or when you were doing the swap and it worked before then it should still work.
Old Apr 22, 2007 | 11:17 PM
F-BOMB's Avatar
Thanks Johnnyboy, I did nothing to the original system, so when I switch to a carb I should still be able to retain the ac. That will be nice since its beginning to get hot in Pittsburgh.
1992rs/ss
Jan 31, 2025 05:10 PM
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
beachrodder
Aug 25, 2015 08:05 AM
86IROC112
Aug 17, 2015 02:00 PM
