IS IT DEAD!!!!!!
Old Apr 23, 2007 | 08:23 PM
woodstock16's Avatar
Car: 1985
Engine: lg4
Axle/Gears: ????????
IS IT DEAD!!!!!!
I was driving my car home and my engine coolant lite went off so I called my mechanic and he said to put coolant in it and drive it to his house and leave it cause he could not get to it till tomarrow well I did and when i got there the engine had vapors coming out from under the hood and the mchanic was not home so I left the car what did I F&*$ up?how much to fix?
Old Apr 23, 2007 | 09:03 PM
ChoobinatoR's Avatar
Re: IS IT DEAD!!!!!!
hehe I had that happen to me once, when I was replacing much of the cooling system. Left a sensor unplugged heh.
So best case scenario is little to no harm done, or a head gasket blew from overheatin which is common I hear.
How long did you run it for? Obviously the longer it ran without coolant the bigger the problem will be...
Old Apr 23, 2007 | 09:13 PM
Car: 1985
Engine: lg4
5 miles speeds up to but not limited to 100 but I filled it with coolant and water(res was full)
Old Apr 23, 2007 | 09:22 PM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
did you only fill the resovior? or did you fill the radiator also? if just the res then you might have a problem.
Old Apr 23, 2007 | 09:37 PM
Yeah, definently fill em both... if that was done, well maybe you just got some hose leak and it's spraying coolant/water on parts. Let's hope so.
Old Apr 23, 2007 | 10:07 PM
Car: 1985
Engine: lg4
I filled both but it was leaking pretty good
I'll post offical problem tomarrow after school
Old Apr 24, 2007 | 09:58 PM
Car: 1985
Engine: lg4
just a water pump 20 bucks to fix
Old Apr 24, 2007 | 11:40 PM
thats good the it was a cheap fix. hope everything else is good.
skinny z
Carburetors
Sep 29, 2015 11:25 PM
92projectcamaro
Sep 29, 2015 07:07 PM
raymondandretti
Sep 27, 2015 06:43 PM
Jonas Earl
Sep 27, 2015 07:39 AM
Johnoooooo
Sep 22, 2015 08:55 AM
