Stripped Head Bolt...hole thing
Old Apr 29, 2007 | 02:52 AM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
I realized that one of my intake bolts on my dual plane manifold looked loose and went to tighten it. It wouldn't tighten and essentially pulled straight out of the aluminum head (heads under a year old, bolts 2 months old.) The bolt is fine, but the threads inside the bolt hole are shot.
A friend of mine recommended getting a metric bolt one size bigger and just forcing it in. I don't understand how this could happen seeing as all the bolts screwed in over half way hand tight...weird.
Suggestions? This isn't causing a vacuum leak at the time so it's not too much of a concern, just an annoyance.
Old Apr 29, 2007 | 03:05 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: Stripped Head Bolt...hole thing
I've got a broken tap lodged in my passenger side L03 head. It's probably not the best situation in the world to run without that bolt in there, but it's working out well enough for me. Just had to make sure the passages in that front corner of the manifold had a realy good seal when I put it back down.
But those were just L03 heads, not nice aluminum ones.
You can always helicoil it if there's nothing in it. Unfortunately mine has a tap lodged in it...
Old Apr 29, 2007 | 06:51 AM
EvilCartman's Avatar
Car: '82 Z28
Go to a parts store and pick up a helicoil kit. Drill hole using the proper drill size, tap it and install the helicoil. It should say on the package what you need for a drill size and maybe on the tap itself.
Old Apr 29, 2007 | 10:40 AM
Thanks guys i'll do that
evilstuie
Jan 9, 2020 08:29 PM
gta90
Sep 15, 2015 04:00 PM
Bob88GTA
Aug 18, 2015 03:31 PM
86White_T/A305
Aug 17, 2015 12:16 AM
