Stalling out
Old Apr 30, 2007 | 06:39 PM
Mental_Paradox's Avatar
Car: 1986 s-10
Engine: 2.8 v-6
Stalling out
87 iroc 5.0 131,000 auto trans.
Starts fine, Idles fine in park or neutral. When you put it in gear it will stall out shortly if you don't give it gas. It runs well during motion, stalls out at red lights etc. The ecm does not show any codes. The owner says this problem has been consistant for the 3 years he has owned it. It was a sunday driver maybe only driven twice a month.
I am thinking of purchasing this car but want to know what I am in for. Any responses would be greatly appreciated.
Old Apr 30, 2007 | 08:04 PM
ResurrectingZ's Avatar
Car: 1987 IROC 1991 RS
Engine: 5.7 TPI 5.0 TBI
Transmission: T-5 , 700R4
Axle/Gears: 2.73 twice
Re: Stalling out
Check timing, ignition system sounds either off or fouled. How old is the fuel in the car?
Old Apr 30, 2007 | 09:07 PM
Car: 1986 s-10
Engine: 2.8 v-6
Re: Stalling out
I don't know exactly how old the gas is probably not more than a month and a half. He drives the car a few times a month and takes it to shows or for a sunday drive. But he says this problem existed when he bought the car 3 years ago.
This car idles fine in park or in neutral. It had a tuneup plugs, wires, filters, and fluids and belts less than 3,000 miles ago.
Old Apr 30, 2007 | 10:43 PM
Re: Stalling out
Any codes? Try tapping on the MAF to see if the engine studders, or unplugging it altogether to see any difference in the response. What about coil? Checked timing with a timing light after unplugging the tan wire? My first check would still be timing, if it had it 3 year ago and he hasn't bothered to dive into the problem he might not know what to do in the first place. Things like this dont just appear and become normal. After that start checking the fuel delivery system, check fuel pressure and do a resistance check on the injectors.
Old May 1, 2007 | 06:51 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: Stalling out
Don't forget to check the IAC.
Old May 1, 2007 | 03:06 PM
Car: 1986 s-10
Engine: 2.8 v-6
Re: Stalling out
No codes.
I forgot to mention it smokes a little on startup, bluish white. I figure it's just a little oil seeping through the seals since they are original with 131k, and not related to the stalling, but if it helps..
Old May 2, 2007 | 05:09 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Re: Stalling out
That sounds like valve seals or valve guides.
Old May 2, 2007 | 09:29 AM
Car: 1986 s-10
Engine: 2.8 v-6
Re: Stalling out
The car starts and idles fine. It ONLY happens when the car is in gear.
Could this be the torque converter?
Old May 3, 2007 | 09:11 PM
Re: Stalling out
Whether or not its in gear, any one of the things could be a potential problem. If it was the torque converter, then you would know. They are built to withstand a lot of abuse and can blow themselves up internally, if it was then it is doubtful it would move at all. Best bet is to check the engine and don't always rely on what someone else says when picking up a car.
Old May 4, 2007 | 03:15 PM
Car: 1986 s-10
Engine: 2.8 v-6
Re: Stalling out
any ideas? i'm gonna have to pass on this deal if theres no resolution.
darwinprice
17
Oct 11, 2015 11:51 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
lanceflame44
Sep 25, 2015 12:28 PM
amcnellis
Sep 16, 2015 04:16 PM
