New Timing chain cover
Old May 2, 2007 | 06:08 PM
89jim's Avatar
My new rebuilt engine seems to be a bit noisy at the timing chain cover. It is the stock cover which I blasted ,cleaned and repainted black. I decided to take it off and check to see what may be hitting. I bought a new cast cover at spring Carlisle show and was told it would fit all SBC. The other night on e-bay I saw one just like it whichs states up to 1985 only. I have an 1989 5.7 so I e-mailed the seller to see if it would fit and his replie was NO. Ok now what should I do? I still am going to take off the old one and check out the noise. If it is hitting inside the cover I want to change the cover. The chain is a new double roller chain and I hope it is OK if not I will change it too. The engines only been run about 45 mins. but I do not want any problems. What is the difference in the timing covers? I also need to know does the timing pointer go in the same place if the motor is now 383?
Old May 2, 2007 | 06:28 PM
strokermotor91's Avatar
Car: 91 Camaro RS
Engine: Small Block
Transmission: TH350 w/ 3000 stall convertor
Axle/Gears: 3.73 w/ powertrax locker
Re: New Timing chain cover
Timing pointer is in the same place, yes. The main difference between the 86 and older engines is that they do not have roller cams. The rollers cams have a longer snout on the front of them. That may be the reason it wont clear.
Old May 2, 2007 | 06:50 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The timing pointer goes in the same place only if your 383's balancer is the same size and is marked in the same location as your factory one.
Old May 2, 2007 | 11:09 PM
Car: 91 Camaro RS
Engine: Small Block
Yes thats what i meant, thanks for the correction
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
MY87LT
Aug 17, 2015 08:43 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
