how can you tell if your fuel pump is going?
Old May 4, 2007 | 06:25 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
trying to find why i'm running lean. code 44.
o2 sensor is brand new(8months old-less than 300 miles on it)
iac is brand new
tps is set to .54
new coolent temp sensor
new cold start switch
k&n air filter setup
new spark plugs, wires, cap, rotor
new radiator
new battery
maf seems to be alright
new fuel filter
done tons of fuel injector cleaner over the course of trips to the gas pump.
car has trouble to idle at cold starts
tap the gas pedal to keep it going till it will idle around 800 and warm up and be ok.
i just installed the coolent temp and cold start switch.
now car sounds like it skipping or misfiring.
heard two pops, like plastic bags filled with air pop.
parked the car and had to go to work.
any ideas guys?
my guess a couple injectors are clogged.
i don't know my fuel pressure yet.
car stumbles and i'm not sure what to do next besides repalce my injectors.
but then again can my fuel pump be semi clogged? letting just enough fuel through to keep it running? and how can you tell?
i should mention people said they tjought it was misfiring before i did the new plugs wires etc.... so that leads me to believe and injector or two isn't firing.
Old May 4, 2007 | 07:07 PM
jonmark1985's Avatar
Car: 89' Pontiac Firebird
Engine: L03 carb Ported #87s new shortblock
Axle/Gears: 2.73 open
Re: how can you tell if your fuel pump is going?
i can hear mine run at idle and when i initally turn the key on
Old May 4, 2007 | 07:54 PM
Bobby_80s's Avatar
Axle/Gears: no idea
the car drives but very poorly
Old May 4, 2007 | 10:07 PM
Bobby_80s's Avatar
Axle/Gears: no idea
come on anybody? any suggestions?
Old May 5, 2007 | 09:31 PM
patgta's Avatar
There is not set way to tell if a fuel pump is going to die. If your lucky what can happen is, you start your car up and it runs for about a second or two and then it dies then you try to start your car up again and it runs fine. That recently happened to me and this kept on happening for about 3 days and then my pump didnt start at all.
With your problem check your fuel pump regulator.
Pat
Old May 5, 2007 | 09:40 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Also there is a chance that you have a leak at the exhaust manifold . Allowing in extra air into the exhast before the O2 .... thus saying it's a lean mixture. do you find that the car is running pig rich ... gas milage suffering since this has happened ?
Old May 5, 2007 | 09:49 PM
Bobby_80s's Avatar
Axle/Gears: no idea
at this point car is running like such crap i cant really tell if its rich.
i'm going through the engine replacing this and that and just seeing what happens. everytime i disconnect the battery and reconnect it after i do some part changes or modifications. car runs like total a$$ untill the computer relearns.
Old May 5, 2007 | 10:49 PM
pearl_iroc's Avatar
Car: 1988 Iroc-Z 28 Camaro
Engine: LSX
Transmission: MN12
when my fuel pump was gonig bad last summer the car would not restart on hott days until the pump cooled down
Old May 5, 2007 | 11:04 PM
Bobby_80s's Avatar
Axle/Gears: no idea
is it possible for the pump to get clogged or semi clogged?
Old May 5, 2007 | 11:21 PM
fast89ta's Avatar
Car: 85 Camaro Z28
Engine: 408 ci bbc
Axle/Gears: 10 bolt 4.11 ratio
The screen on the pump could get clogged if u have dirt in the tank...Have u changed the fuel filter??? They seem to clog up often in these cars.
Old May 5, 2007 | 11:53 PM
Bobby_80s's Avatar
Axle/Gears: no idea
brand new fuel filter. but i think some injectors r clogged. im replaicng them soon. along with fuel pump relay/connector. also putting on new stock regulator diaphram with crane adjustable screw top. see how my cars runs aftrer that.
still need to check my fuel pressure up to this point.
Old May 6, 2007 | 09:16 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
I found that my passing gear didn't have as much grunt as it used to.
I scanned it and found that I was running a bit lean which started to retard my timing.
I checked fuel pressure static, running, and then by squeezing the return line. Squeezing the return line did not increase the fuel pressure like it should have.
Those things told me pump. I replaced the pump and now she's back to normal.
Old May 6, 2007 | 11:59 AM
Bobby_80s's Avatar
Axle/Gears: no idea
ok i gotta call my mechanic and at least price out what it would cost to install a new pump.
i didnt know the computer retards your timing if your running lean.
at first i thought it was something wrong with my ecm or esc or knock sensor retarding my timing. because car ran like crap and engine was way hotter then usual which is a sign of retardation.
good one less thing to worry about at the moment.
i'm going to check my fuel pressure and then replace my regulator with an adjustable one only cuz i like to have options, and change out my injectors with a fresh set of ford racing svo injectors. i hear tehy are pretty reliable. id like to stay true with GM but not for 198 bucks per injector screw that.
thanks for the tips up to this point guys.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
