TPI... sticky throttle in gear
Old May 4, 2007 | 10:42 PM
r9559's Avatar
I need some help.... I year ago I swapped out my orginal intake and runners for a edlebrock intake and accel runners and 24 lbs svo injectors. Since then while driving the throttle sticks @ 1500 rpm, a tap of the pedal will drop the revs to normal. What is the problem????..... I eliminated the tb cuz I tried another one with no change, don't think it is a vacuum leak cuz the motor is freshly rebuilt. Bad tps??
Thanks.
Old May 4, 2007 | 10:44 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: TPI... sticky throttle in gear
does the cable move freely when disconnected from the throttle body? does the thottle body snap shut with the throttle cable disconnected or the cruise control cable disconnected?
Old May 4, 2007 | 11:54 PM
r9559's Avatar
tb and cables are good, everything moves freely. I guessing the ecm is causing the problem. Not sure how to trouble shoot the problem. All I do know is I didn't have this issue before the parts swap.
Old May 5, 2007 | 09:40 AM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
If you swapped the TB and used the same IAC, it may be the problem. See this thread for cleaning and lubing it:Cleaning & lubricating the IAC
Old May 5, 2007 | 10:35 AM
r9559's Avatar
IAC was inspected before install.
Old May 7, 2007 | 08:54 AM
r9559's Avatar
I lubed up the throttle plates and it seems fine. I'm not used to the easy fixes
italiano67
Dec 11, 2016 09:21 AM
86White_T/A305
Aug 17, 2015 12:16 AM
Armored91Camaro
Aug 12, 2015 09:41 AM
novaderrik
Aug 10, 2015 12:44 PM
