fuses?
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
fuses?
where are the injector fuses for a 1986 tpi v8 305 5.0 engine?
and what values are they?
and is the fuel pump/ecm fuse supposed to be 15amp or 20amp?
and why do you have to replace it everytime you take it out?
Re: fuses?
The two fuses for the injectors are located in the main fuse panel in the passenger compartment. They are 10A.
The ECM/FP fuse should be 20A. It does not have to be replaced with a new fuse just because it is removed from the holder (presumably to clear ECM codes). You only need to replace it if it fails.
Axle/Gears: no idea
Re: fuses?
thanks, for some reason someone put in a 15amp fuse. car drives so it works but now i know its supposed to be 20amp ill change it out.
damn i hope it didnt put a huge strain on the ecm.
gta892000
Sep 16, 2015 12:37 AM
