Several questions about braided fuel line..
Old May 12, 2007 | 05:10 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
What is the proper way to connect braided fuel line to steel lines? I need to connect my -8 fuel line to my 3/8th feed line...
Old May 12, 2007 | 07:47 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Several questions about braided fuel line..
You can flare the hard line and use a tube nut and sleeve, or you can use a self-threading adapter.
Old May 13, 2007 | 12:21 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Quite a few ways it can be done...
What kind of setup is this?
Are we talking a 'pump in tank' semi-high pressure feed line, or just a suction line with the pump on the block?
I just used a compression fitting on mine when i plumbed in the new pump and carb to the existing steel lines.
Old May 13, 2007 | 01:18 PM
89RsPower!'s Avatar
Its a pump in tank, I'm converting from tpi to carb. I can't seem to find the proper fitting for 8 to 3/8ths anywhere though.. I can find 6an to 3/8ths.. Will I have to switch to a smaller line???
Old May 13, 2007 | 08:09 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
There's not much point connecting a -8 hose that has an I.D. of 1/2" to a hard line with an I.D. of half that.
Old May 13, 2007 | 11:43 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
Its not going to help, no. But if thats what you have to work with, thats what you have to work with!
Reducers are definately available, aeroquip "performance" part # FCM2410
I would use one of those reducers, then on the steel tube use a flareless ferrule (#FCM2492) and a nut (#FCM2497) and your good to go.
You can find the catalogue here if you want to look around a little more, or see what im talking about---
http://hydraulics.eaton.com/products...E-MC001-E2.pdf
Old May 14, 2007 | 10:02 AM
89RsPower!'s Avatar
Found all the fittings I needed, thanks guys, and yeah a friend gave me 10ft of -8 an earls braided line so it was cheaper to buy the adapter fittings than switch to a smaller line and buy the nessicary fittings for that
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
fasteddi
Sep 2, 2015 10:29 AM
redmaroz
Aug 16, 2015 11:40 PM
