recommend a distributor?
Old May 14, 2007 | 12:50 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Hey, i'm thinking about getting a new distributor to replace my stock non-cc setup on my carbed car.
Rather than get a new high perf coil and module, I figured it'd be close to the same cost to get a whole new unit, with a nice new free moving advance mechanism etc.
I welded up the advance slots a bit, but i'd prefer to have them adjustable. I'm not sure how this typically works, bushings? Something else?
What's my best bet here, anyone know a part # they can toss me? I'd rather not use an ignition box, I just want a stand alone distributor, but should I just get a relatively cheap style one, and buy an advance kit with bushings (does that actually limit my mech travel?) or should I spend the big bucks and get one of those distributors that advertise an adjustable amount of mechanical advance travel? (for the life of me I can't find that distributor anymore either?)
Old May 14, 2007 | 01:02 PM
The_Wraith's Avatar
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
Re: recommend a distributor?
http://cgi.ebay.com/ebaymotors/NEW-S...QQcmdZViewItem
Seems like a great deal to me. There are several as well.
Old May 14, 2007 | 01:11 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The bushings in the "weight and bushing" sets are just to replace the worn-out stock pivot bushings, they don't limit the advance.
If you've got the cash, then try the MSD 8394 E-curve. Add an external coil and it's ready to run. There are no annoying weights and springs to deal with, and the advance curve you set is exactly the advance curve you get.
Second best would be any ready to run "billet" distributor (MSD 8360 or equivalent). Third best (and cheapest) would be a rebuilt GM distributor.
Old May 14, 2007 | 01:26 PM
Sonix's Avatar
Car: 1982 Trans-Am
Hmm, well, the main thing I want to get, is a complete distributor. $300 and I still need to buy a coil is kinda hard to swallow. In spite of the fact i'm hoping to get this as a grad present...
You think 3rd best would be a rebuilt GM? Reason i'd like to avoid that, is that I want the easily adjustable (limitable) mechanical travel, without welding or grinding. Otherwise i'd just rebuild my dist with a new coil and module. I'm also worried I might have pressed on the advance slot area in the wrong place. It seems to have a bit of vertical slop in it. That's why i'd prefer a new piece.
Anyway, I figured I could get a limitable mech travel distributor for roughly the same price as the $150 basic units, but no such luck. Is this one by Pertronix a good one?
http://store.summitracing.com/partdetail.asp?autofilter=1∂=PNX%2DD1000&N=700+0&autoview=sku
$220 isn't *too* bad.
Old May 14, 2007 | 01:33 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Adjusting the amount of advance isn't as important as adjusting the rate.
That Pertronix one would be fine. So would Summit's own HEI distributor, with an advance kit.
Old May 14, 2007 | 01:36 PM
Sonix's Avatar
Car: 1982 Trans-Am
Well, the rate is easy, with the springs eh? That I can buy a kit for, and do on any distributor, so I take that for granted.
I just welded up my slots to have 24* base timing, and 12* mech travel, i'm thinking i'd like to bring the base down a tad, open up my mixture tubes, and increase the mech travel. Either way, i'd prefer it to be easy to change.
Alright, cool, thanks. I'll put the Pertronix one on my wish list then.
Old May 14, 2007 | 01:42 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Easy to change is why I went with the E-curve. I'm also using an MSD 6AL though, so I could also have used Crane's electronic advance distributor that only has a magnetic trigger. I just got tired of all the trial-and-error work messing around with cheap spring and weight kits on the distributor machine. Doing it on the car is even worse.
Old May 14, 2007 | 01:51 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
I went with a proform for my car there pretty nice piece. i think I paid $170 for it.
http://www.proformparts.com/mistore/...pany_id=100719
Old May 14, 2007 | 02:23 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
i went with a reman a month or so ago. added the crane hei advance kit, 800-3200 springs. found out my fancy 3 year old hi-po coil was causing my miss, so i shelved that in favor of a low-po autozone special.
love the advance curve, no more bogging at all. wish i could limit the mechanical i'd be one happy lark, but so far so good. maybe MSD coil/module down the road, but i just bought an edge TC and sending the 700r4 in to be rebuild...
amargari
Nov 10, 2015 02:09 PM
skinny z
Oct 5, 2015 06:23 PM
Damon
Sep 26, 2015 04:29 PM
camarohelp
Sep 22, 2015 03:19 PM
Jlanz55
Sep 6, 2015 03:05 PM
