89 camaro wont start VATS?
Old May 16, 2007 | 08:35 PM
nkatch22's Avatar
Car: 1989 Camaro RS
Engine: 305 V-8
I have an 89 camaro with the VATS system in it. Car wont start. The gauges work when I turn the key. Checked the fuses, everythings fine. I don't think its the computer because the fuel pump buzzes when the key is turned. I tried maneully starting it and it turns over but wont ignight. I replaced the lock cylinder and VATS (black box) last year.
Im hoping its not VATS acting up again. Does anyone know of anything else I should check? if it is VATS does anyone know how to bypass it?
Old May 17, 2007 | 06:27 PM
nkatch22's Avatar
Car: 1989 Camaro RS
Engine: 305 V-8
Re: 89 camaro wont start VATS?
ttt
Old May 18, 2007 | 08:11 AM
smithtc's Avatar
Could be VATS.
Would have to turn it off in the ECM and bypass the starter relay, located under the kick panel on the driver side...by your left foot.
hehe...for quite a while, I started my car with a paper clip.
Anyway, this stuff has been documented pretty well on these boards...try and look it up for all the details.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Jae992
Aug 27, 2015 09:07 AM
stalkier
Aug 13, 2015 12:59 PM
92camaroJoe
Aug 13, 2015 06:07 AM
djmarch
Aug 9, 2015 05:27 PM
