zz4 hype??
Old May 18, 2007 | 06:45 PM
19Irocz86's Avatar
Car: 1986 Iroc z z28
Engine: 305 tpi
zz4 hype??
i was just wantin some basic info on this motor, i hear alot of hype about it. what all can be done with it from the factory? what kind of power can it hold? i bealive i seen one in a chevy mag that had fastburn heads and a comp cam i belive and it was making close to 450 hp. does this sound right??
Old May 18, 2007 | 07:09 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Just putting the Fast Burn heads on ups power from 355 to 385. 450 HP isn't unreasonable.
Old May 19, 2007 | 06:55 AM
zz4monte's Avatar
Car: 87 Monte Carlo ss
Engine: ZZ4 1.5 rollers 650DP
Transmission: Probuilt 700-R4
Axle/Gears: 8.5 GN 3.42
Re: zz4 hype??
Sure, but I think it would idle like crap for the street. I think one of those GM crate motor dealers sells a package with a big comp. cam stick and AFR heads and it makes over 450hp but I don't know how streetable it is at that point. I have seen several zz4s with fastburn heads and hotcam package run mid 12s in the 1/4mile with about 420hp and are still daily driven.ZZ4's bottom end is good for about 500hp.They are good motors but yes there is alot of hype about how fast they are.Here are some examples of performance in 1/4mile.
ZZ4 355hp 13.2-13.8
ZZ4 385hp (fastburn) 12.9-13.5
ZZ430 (most people report more around 420hp at the crank) 12.5-12.9
These are just what I have seen but every car and driver are different.
Old May 19, 2007 | 05:19 PM
19Irocz86's Avatar
Engine: 305 tpi
Re: zz4 hype??
what kind of power whould a set of brodix track 1 make on it? also the times u posted up are they in a f-body with full factory wait?
lt500r55
Sep 1, 2021 01:30 PM
italiano67
Sep 22, 2015 08:42 AM
anesthes
Sep 18, 2015 12:34 PM
Magman
Sep 13, 2015 12:14 AM
italiano67
Aug 31, 2015 06:04 PM
