Head Gasket
Old May 19, 2007 | 08:35 AM
MattSloc's Avatar
Car: 1986 Camaro Iroc-z
Transmission: 700r4 w/ custom shift kit
Head Gasket
I'm taking my 305 TPI apart to repair the head gasket, hopefully this will stop the access exhaust smoke. Ive got the right head off but the left one is being a major pain, there's one bolt i cant get to? help ?
Old May 19, 2007 | 09:31 AM
jaysfs's Avatar
Car: 91 z28, 07 trailblazer ss
Engine: lt1lt4 hot cam,ls2
Transmission: t56
Re: Head Gasket
go to sears and get a swivel etension,just used that on mine, also you might want to take your heads in too get new valve seals and milled. It`s not too expensive,i paid 120 for both.
Old May 19, 2007 | 03:51 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: Head Gasket
Hastings makes a spring-loaded Universal joint socket extension. Its a HUGE help for bolts that are hard to access. It flexes like a U-joint socket, but doesn't just flop all over the place. Best too I ever bought - I did all the plugs in my '97 LT1 car from the top in 2/3 the time it normally takes. These things are worth their weight in gold for hard to get stuff.
Old May 20, 2007 | 07:44 PM
MattSloc's Avatar
Re: Head Gasket
Yeah i got it off with a little bit of wrestling, man chevy tucked the heads right under everything..
Old May 21, 2007 | 02:26 PM
Air_Adam's Avatar
Re: Head Gasket
When you've done this on an LT1, the 3rdgen isn't so bad lol.
Old May 21, 2007 | 02:31 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Re: Head Gasket
I'd say...just be glad you don't have the cowl to deal with.
3rd gen money
Sep 8, 2015 11:40 PM
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
qz6lwp
Aug 20, 2015 08:10 PM
