Tall Valve Covers - A/C Clearance
Old May 21, 2007 | 07:57 AM
AmericanIROC's Avatar
Pulled the 350 from my Jeep but forgot to check a/c compressor clearance to the stock valve covers.
I'm going with 1.5 roller rockers so I need taller valve covers but I'm concerned about the a/c lines clearing the covers.
Anyone here running tall centerbolt covers with the a/c compressor mounted on the passenger side?
Before I order valve covers I'd also like to know how everyone is routing non smog TPI pcv, etc... any photos would be appreciated.
Old May 21, 2007 | 08:02 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Re: Tall Valve Covers - A/C Clearance
I dont have center bolt but I do have tall valve cover on my 84 Z28 and it has a 355 and the fit fine when i had the ac in the car.
Old May 21, 2007 | 08:49 AM
joecautela's Avatar
I've got the Proform Aluminum covers and 1.6 rr's. A/C line clearance is no problem. On the left side I use the std. location for the pcv and oil fill cap. On the r/s I blocked off the return breather line to the throttle plate and went w/ an old style open breather. These photos are after the header install but before I decided to de smog. The breather, pcv and oil cap are all visible and did not change, Joe
Attached Thumbnails Tall Valve Covers - A/C Clearance-headers-025.jpg   Tall Valve Covers - A/C Clearance-headers-028.jpg   Tall Valve Covers - A/C Clearance-headers-016.jpg
my86bird
Oct 23, 2015 12:20 PM
New2Chevy
Sep 28, 2015 12:35 AM
Victor6
Aug 30, 2015 02:09 AM
mustangman65_79
Aug 8, 2015 01:18 AM
