I think i have a vented gas cap, is this hurting anything?
Old May 21, 2007 | 11:36 PM
BigBoi4Lyph's Avatar
Car: 89 Iroc
Engine: 5.7 TPI
Axle/Gears: 9 bolt Borg Warner Disk Brake Posi
So i replaced my injectors and latly its been hotter and i keep smelling raw fuel but their are no leeks what so ever from the engine or under the car, no gas smell under the hood. so i started sniffing and it was strongest around me gas cap,
So i know the gas cap is not stock its a locking cap but how would i tell if its vented or bad? im going to buy a non vented cap tommorw but is having this vented cap hurting anything?
also ive never hear a hiss when i remove the cap like ive heard on many other cars.
Old May 22, 2007 | 12:13 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Re: I think i have a vented gas cap, is this hurting anything?
A vented cap wont hurt a thing...
Old May 22, 2007 | 12:42 AM
Car: 89 Iroc
Engine: 5.7 TPI
I didnt think so but it would deffinatly give me a faint smell of raw fuel epscally when its hot or when im driving hard and the gas is sloshing around right?
thats what im concerned about.
a loss in tank pressure wouldnt cause anything to go out of wach? maybe less gas milage cuz some of its evaporating?
Old May 22, 2007 | 10:02 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Make sure you check your vent line that goes to your charcoal canister.
Nope. What evaporation does happen is negligible.
Old May 22, 2007 | 04:56 PM
Dirtbik3r's Avatar
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
Even with newer obdII monitored evap systems, they still uses a vented cap as a backup. See if the smell is coming from around the canister also.
1992 Trans Am
May 10, 2023 07:19 PM
chazman
Aug 28, 2018 03:25 PM
777Shock777
Oct 29, 2015 04:30 PM
chazman
Aug 22, 2015 02:01 PM
86White_T/A305
Aug 17, 2015 12:16 AM
