help me tune my motor?
Old May 22, 2007 | 05:44 PM
intex1982's Avatar
Car: 89 formula/00 z28
Engine: carbed 350/ls1
Transmission: 700r4/ a4
Axle/Gears: 3.23 posi/ 3.73 posi
ok i just set the timing rgt 18deg at 700 rpm and 35 degs all in at 2500. ok so how can i set my carb to run better? bc the car just dont feel really that fast
what color spring should i use in the vac secs
Old May 22, 2007 | 10:34 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: help me tune my motor?
the secondary spring is determined by how much vacuum the engine produces...
35* mech advance?
18+35= 53*
or 17* mech advance...
if your at 35* mech advance plus the 18 base i wouldnt run the vacuum advance are you?
you might get better help in the carb board for tuning help
Old May 22, 2007 | 11:24 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
No kidding. No offense, but everything you said was wrong.
Vacuum is used to determine the power valve, not the secondary diaphragm spring. Basically, start with a "heavy" spring, test successively lighter springs until you feel the secondaries opening (aka - "bog"), then go back one heavier spring.
18 initial with 35 total means there is 17 degrees mechanical advance. You definitely need vacuum advance on top of that for street driving. If it starts and idles okay, then you probably don't have an issue there. 36 is typical for SBC's, though. One degree probably won't make much of a difference.
Need to know more details about your engine, tranny, gears, etc., to say much more.
Old May 22, 2007 | 11:30 PM
Car: 91 RS
Engine: 350 vortec
good point... carbs are new to me i thought you could choose a spring based on the engine vacuum at idle...
and i was trying to figure out if he meant 17* mechanical or 35*
Old May 23, 2007 | 12:02 AM
intex1982's Avatar
sorry my sig didnt show but it a 350 bored 40 over with 10.1 to1 cr trick flow heads 2.02 1.60 195 runner edelbrook perfrom rpm intake 750 holley msd 8.5 wires summit blueprinted hei dist .473 .486 zcam rollar rockers 4.10 posi rear, 350th with mild shift kit 2200 stall convertor, Heddman 1 5/8 shorty hedders, custom y pipe complete 3 inch ext and flowmasters.
1992rs/ss
Jan 31, 2025 05:10 PM
MustangBeater20
Oct 29, 2022 09:20 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
ezobens
Aug 19, 2015 10:29 PM
Bradsaundry
Aug 12, 2015 12:34 AM
