Distributor Question
Old Jun 2, 2007 | 08:54 PM
geehumshriber's Avatar
So I've successfully installed my carb, sans electronics. Now I'll be putting on a vacuum distributor instead of the computer controlled one (for reliabilities sake). I understand that this needs a different plug than the electronic distributor; can anyone tell me what to do for this? I understand there is a vacuum hose that goes to my carb, and I'll figure out that one later, but in terms of wiring up my distributor, how do I do this? Where do I get the different plug and then how will I end up wiring it up?
Thanks!
Old Jun 2, 2007 | 08:58 PM
82CAMAROBBC's Avatar
Car: 1982 Camaro
Engine: 454
Transmission: TH350
Axle/Gears: 410
Re: Distributor Question
it depends on what dizzy you get... HEI is easy.. 1 12V switched wire..
Old Jun 2, 2007 | 09:00 PM
I think it's an HEI, how does the wiring work for this?
Old Jun 2, 2007 | 09:16 PM
Car: 1982 Camaro
Engine: 454
Transmission: TH350
Axle/Gears: 410
HEI will have the coil built in the dizzy.. If this is what you have, look on top of the cap. It will be labeled. Batt, Tach.. Autozone should have the pigtail to the dizzy, or you can get a harness from a carbed car 82-86. All you have to do is run a 12v switched wire to Batt connector, and splice in the Tach (white wire in the driver side harness). Some of the cars have a pink wire on the driverside harness. This would be for the Batt on HEI.
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
beastin91rs
Oct 9, 2015 07:38 AM
86IROC112
Aug 17, 2015 07:57 PM
redmaroz
Aug 16, 2015 11:40 PM
