charcol canister
Old Jun 6, 2007 | 02:52 AM
Firebird sweden's Avatar
Car: Firebid Cab-92/1989 TTA
Engine: 383 HSR TPI
Transmission: TH700r4
Axle/Gears: 4.10
charcol canister
Hi!
Were chould the rubber housing from the charcol canister go?
To tb or somewere else.
Have to get rid of that fuelsmell.
Thanks.
Old Jun 6, 2007 | 10:14 AM
Vader's Avatar
Re: charcol canister
I will guess that you are asking about the rubber HOSE from the canister.
The purge hose should connect to the throttle body, but through a purge conrtol solenoid valve mounted to the top of the canister. The vapor hose should connect to the tank vent fitting.
There is another fitting on the EVAP (charcoal) canister which may or may not have a hose on it. That should be an atmopheric vent line.
Old Jun 6, 2007 | 12:04 PM
Engine: 383 HSR TPI
Axle/Gears: 4.10
Ok Thanks!
I suppose its that small inlet under the tb right?
Old Jun 6, 2007 | 05:35 PM
Vader's Avatar
Teh small vacuum connection on the bottom of the TB is a timed vacuum port for both the EVAP purge signal and the EGR solenoid source. The purge hose from the canister connects on the right side of the TB.
Old Jun 6, 2007 | 06:52 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
This will help you out.
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
Old Jun 6, 2007 | 06:53 PM
Auggie's Avatar
Car: 1984 Z28 Camaro
Engine: H.O. 355 NOS
You might want to check the canister filter.
Auggie
Old Jun 6, 2007 | 09:13 PM
Vader's Avatar
IIRC, the last year for a replaceable filter on the EVAP canister was 1987.
Old Jun 7, 2007 | 01:16 AM
Engine: 383 HSR TPI
Axle/Gears: 4.10
Thanks All!
That picure done it.
Quzyle
Oct 15, 2015 03:35 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
reactor60
Sep 22, 2015 01:44 PM
Racerx974
Sep 19, 2015 10:16 AM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
