Cruise Control problem
Old Jun 8, 2007 | 07:12 PM
faceinacrowd44's Avatar
Hi, I'm a first time poster and I've got a small problem.
My cruise control will no longer work. It's worked before, it worked a few days ago, and now when I press the button to set the speed, it won't engage.
I don' think it's a loose wire since the wipers still work, but I'm thinking it may be the lever?
Anyone have any relevant similar issues?
It's a '90 RS 3.1l
Thanks!
Old Jun 8, 2007 | 07:16 PM
dustpusher's Avatar
Car: 88 IROC-Z
Re: Cruise Control problem
I did with my 88 IROC it was the brakelight switch.Only costs 8or9 bucks.After I fixed that cruise worked again for a little while then my lever went bad and havent had issues since.
Old Jun 8, 2007 | 07:24 PM
i'm assuming that's in the cruise lever area? or connected to the lever?
i apologize for being such a layman. ha
Old Jun 8, 2007 | 09:00 PM
dustpusher's Avatar
Car: 88 IROC-Z
Brakelight switch is by the peddle under the dash.It isnt very hard to change.Just make sure you adjust it or you wont have brake lights.
Old Jun 8, 2007 | 09:08 PM
GeeJenn91RSV8's Avatar
Car: 1991 Camaro RS
Transmission: 700 R4
Is your speedo working? I have a 91 RS and one time my speedo quit working and I lost the use of my cruise control until my speedo was working again.
Old Jun 26, 2007 | 08:33 PM
semiller26's Avatar
Car: 1986 Trans Am
I have the same problem i think I may have mucked something up when I changed the ignition switch. I'll try changing the brake light switch and see if that will fix it
eightsixseven
Dec 16, 2024 01:50 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Street Lethal
Aug 13, 2015 08:28 PM
stalkier
Aug 13, 2015 12:59 PM
Bull86
Aug 10, 2015 05:43 PM
