quick chip question- please help
Old Jun 9, 2007 | 11:08 AM
punkdude908's Avatar
Car: 1983 Pontiac Firebird
Engine: LG4 305ci 4bbl
Axle/Gears: 10-bolt open diff.
i did a search and couldn't find exactly what i was looking for.
i was looking @ the JET performance chips on summit racing today and i was wondering if it would do anything on an 83 computer controlled carb'd LG4.
if so, should i get the chip for the LG4 or the L69? would it make any difference? could it hurt anything? stage 1 or 2? (i have the L69 air cleaner, flowmaster exhaust w/ high flow cat, and a 180* thermostat- stock other than that)
and i know a lot of you absolutely hate the aftermarket chips but i'm not looking to go racing- its just a daily driver that i want to get better-than- stock performance on.
any help/ advice/ comments are greatly appreciated.
Old Jun 9, 2007 | 07:48 PM
Re: quick chip question- please help
anything guys? i could really use a little help- i'm kinda clueless about the whole performance chip thing.
Old Jun 9, 2007 | 07:54 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
all a chip is going to do is give a little more timing and if you are very lucky a little more fuel...
you can accomplish the same thing by advancing the base timing for free...
those "performance" chips are useless if you have the mods to need a new chip then you should invest in your own tuning equipment it will cost about the same as just one of those performance chips
Old Jun 9, 2007 | 09:53 PM
yea but the chip will work even though i have a carb and not fuel injection?
Old Jun 9, 2007 | 09:55 PM
Car: 91 RS
Engine: 350 vortec
(there is a possiblity) but my answer is NO!
Old Jun 9, 2007 | 10:19 PM
is there anyone else who has a computer controlled carb who has some kind of performance chip? anyone who has experience with the CCC ECM's?
Old Jun 9, 2007 | 11:17 PM
Vader's Avatar
Perform a search in the DIY/PROM forum.
Old Jun 10, 2007 | 12:18 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
does it really matter if it will work or not on a carb car as more often then not they cause more problems then they solve.
again all they do is advance the timing a tad. rather then spend 100+ bucks on one go out to your car take out a wrench loosen the distributor and advance it. there you have the same effect and just saved a lot of money. oh and to make sure you get the full effect that the chip would give you advance it far enough to where it starts to ping. your not doing it right but you did get the same effect as that "performance" chip
Old Jun 10, 2007 | 12:28 AM
Car: 91 RS
Engine: 350 vortec
oh you forgot you need to wear a blind fold and just spin the dist where it lands is good
Old Jun 10, 2007 | 12:38 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
actually you know that sounds about right.punkdude these chips are a generic one size fits all tuning. which means the guy who tuned the chip has no idea what combo of parts your running. what type of gas you run. what your climate is like, what temp of thermostat you use, or anything else about your car. but he is going to make something that will adjust the tune of your car. does that really sound like a smart safe and sound idea for the longevity and performance of your vehicle? if so I can save you a couple bucks and throw something together to tune your car as well under the same situation.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
3.8TransAM
Sep 27, 2015 08:37 PM
