Valve Tapping
Old Jun 10, 2007 | 09:13 PM
redline_racing's Avatar
Valve Tapping
Toady I had someone look over my car and the said i have a val tap,plus in burning oil like crazy its smokey all out of the exhaust at lights,in park or just simply starting the car cause someone help me fix this asap
Old Jun 10, 2007 | 09:32 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
Re: Val Tap
How many miles on the motor. Could be leaking rings or bad valveseals. Exaust leaks can be mistaked for valve tapping. Take the valvecovers off and check the rocker arms, see if any are loose.
Old Jun 10, 2007 | 09:45 PM
Re: Val Tap
engine has 159k i know i know thats alot of dam miles please help
Old Jun 11, 2007 | 12:18 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Val Tap
There's your advice, go to it. He's not talking to hear his own voice. Just have it idling, warmed up, then shut it off and remove a valve cover, and start it back up, watch the rockers. If they are all ok, none are loose, then check the other side.
Go from there.
Old Jun 11, 2007 | 12:37 PM
Re: Val Tap
thx
gta892000
Sep 16, 2015 12:37 AM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
Ragtop Man
Sep 12, 2015 12:23 AM
dimented24x7
Sep 6, 2015 03:51 PM
