305 HIGH oil pres
Old Jun 16, 2007 | 09:17 PM
gasguzzler's Avatar
Car: 1992 pontiac firebird
Axle/Gears: dunno? stock for sure
305 HIGH oil pres
I've had my 92 firebird for a few weeks now. one of the first things i did was put a new oil pres sending unit in it. i noticed in the mornings or whenever the engine is cold the oil pres pins the gauge ( over 60 psi ). it souns like the valves might be tapping a little for the first min or 2 but other then that everything is normal. after the car is running for about 10 mins or when the water temp gets around 160 the oil pres seems normal about 20-25 psi at idle. but the cold oil pres seems very high does this sound normal?
I'm also using a conventional 10-30 oil
Old Jun 16, 2007 | 09:44 PM
gasguzzler's Avatar
Re: 305 HIGH oil pres
anyone?
Old Jun 17, 2007 | 02:12 PM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
Seems normal to me. Mines 60-65 cold idle, 25-30 hot.
Old Jun 18, 2007 | 02:27 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
My 350 has around 60psi cold and around 25psi hot at idle. Thats with a 10/30 oil.
Old Jun 18, 2007 | 10:01 AM
Overcast32's Avatar
Engine: 305 TPI - LB9
Transmission: 700R
I was curious about that in mine too - it's still stock, unmodded for now. It runs pegged over 60 too - I'll pay attention to see if it calms down once it's warmed up, but I really think it does. I know I've seen it in normal range as well, just didn't pay attention to when.
Derick15
Sep 17, 2016 05:28 PM
Navy8125
Aug 21, 2015 09:32 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
