can these lifters/valves be adjusted
Old Jun 18, 2007 | 09:18 PM
dennisgramm's Avatar
Car: 1983 Camaro Z28
Engine: 5.0L HO
Transmission: 5speed
Hello,
I have a z28, 305 H.O. engine, just recently it sounds like one of the lifters is tapping, the car only has 72k miles, I do not hot rod it, really runs good. My mechanic suggested I put in a oil stabilizer, which I did, it quieted it some, but here is my question....can this be adjusted under the valve cover? I am assuming it is a hydraulic lifter making the noise, and I do not want to put wear on camshaft...is this hard, it seems like it could be done easily???? appreciate any suggestions, thanks
Dennis
dennisgramm@verizon.net
Old Jun 19, 2007 | 08:27 PM
Damon's Avatar
Re: can these lifters/valves be adjusted
All small block Chevys came with adjustable rocker arms- so, yes, you can adjust it. It's a simple matter of turning the big nut in the center of the rocker arm. However, they RARELY go out of adjustment. Usually if something starts tapping it's because a part is on it's way out somewhere- lifter collapsing, rocker stud pulling out, broken valve spring, bent pushrod or badly worn valve guide are the usual culprits that spring immediately to mind.
InfernalVortex
Apr 20, 2021 11:31 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
meeklay812
Oct 1, 2015 03:46 PM
