Rings or Valves
Old Jun 19, 2007 | 12:09 PM
408Firebird's Avatar
Car: 1991 Firebird
Engine: 408 sbc
Transmission: Th-350
Axle/Gears: 10 Bolt / 3.73
Rings or Valves
What is the best way to find out if it is my rings that are bad or the valves are bad?
Old Jun 19, 2007 | 12:31 PM
Re: Rings or Valves
Ummmmm..... background check?
Seriously, what makes you think that EITHER is bad? Or, that one or the other MUST BE bad? Or, what are the symptoms?
Old Jun 19, 2007 | 01:56 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
Re: Rings or Valves
have you checked compression readings
are you burning oil?
if so at what times ? idle ? or higher rpm ?
are spark plugs oily on the tips and caked with burnt oil ?
Old Jun 19, 2007 | 02:11 PM
Car: 1991 Firebird
Engine: 408 sbc
Re: Rings or Valves
I have not checked the comp readings yet but I am burning alot of oil at all times. The spark plugs also have oil caked on them. Sorry I didnt add some more info at the start.
Old Jun 19, 2007 | 03:01 PM
Re: Rings or Valves
What happened when you just "shotgunned" the valve guide seals? As you already know from when you did it, that was cheap and quick ($30 and an afternoon, if you weren't in a hurry); did it help at all?
Old Jun 20, 2007 | 12:54 AM
Car: 1991 Firebird
Engine: 408 sbc
Re: Rings or Valves
So do you think it is just my valve seals? Becuase the oil comes out at all times, the spark plugs have oil on them. The owner before me used nitrous on it more then just a few times so would that also lead to bad valves?
Old Jun 20, 2007 | 05:49 AM
Re: Rings or Valves
Not necessarily...
But I DO think it takes $30 and about 4 hours to change the valve guide seals, and I think it takes about $1500 and a couple of weeks to change the rings, along with everything else that gets disturbed in the process.
A compression test is not conclusive about oil consumption. Valve guide seals aren't involved in it at all, yet can pour unbelievable amounts of oil into the intake. Easiest way to figure out what it is, is to change something and see what happens.
Hmmm..... $30 & 4 hours, or $1500 and 3 weeks... whaddya think? Where to start?
Old Jun 20, 2007 | 11:21 AM
Car: 1991 Firebird
Engine: 408 sbc
Re: Rings or Valves
Ok, thanks alot for your help is their any guides out their that will show me how to change valve guide seals?
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
DARKmj16
Sep 9, 2015 04:07 PM
BOOT77
Sep 5, 2015 03:55 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
