hot starter
Old Jun 19, 2007 | 11:28 PM
avro206's Avatar
Car: 89 Formula
Transmission: TH 700R4
hot starter
whats the cure for this?
Heat shield or wrap?
Old Jun 20, 2007 | 06:28 AM
dennisgramm's Avatar
Car: 1983 Camaro Z28
Engine: 5.0L HO
Transmission: 5speed
Re: hot starter
Hi, I think I may have same thing as you, my car starts fine in cold or if when engine cooler, I tried new NAPA starters,batteries,etc....my mechanic says I should get a low reduction starter, this will take care of problem, he says they are made to easily start especially in heat...I guess they use these also to start high compression engines, those that operate under heat conditions. I guess because of the lower gears in starter it turns easier, and fires up better...good luck, hope this helps
Old Jun 20, 2007 | 06:48 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: hot starter
Yes yes and yes.
Old Jun 20, 2007 | 08:00 AM
Re: hot starter
Don't bother with any of the mythical "heat soak" cures.
The REAL PROBLEM is the stupid weenie POS Stone Age relic Delco direct-drive starter.
Get rid of that; put a gear reduction unit of some sort on it. ANY of the aftermarket "mini-starters" are better than the stock one, or, the stock LT1 one is also a good choice. Costs about the same for any of them; expect to pay $150-180, and to NEVER have to replace a starter again for as long as you own the car, as well as NEVER having to worry again about whether it's going to start this time or not.
Old Jun 20, 2007 | 09:39 AM
soultron's Avatar
Car: 87 trans am
Axle/Gears: 3.42 SLP rear
Re: hot starter
Well, sofaking is right, but I was having trouble with a heat saoked starter at the track (drifting). I worked on the cooling system (radiator and coolant) and bought a summit starter wrap. Starts every time I stall it (doh).
Old Jul 15, 2007 | 05:30 PM
avro206's Avatar
Car: 89 Formula
Re: hot starter
I tried the wrap. AFIK it did not do a thing.
What does anyone think of the this starter off ebay?
http://cgi.ebay.com/ebaymotors/CHEVY...mZ270144883673
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
ironbmt
Sep 27, 2015 06:00 AM
