Stock 350 Internals
Stock 350 Internals
On a stock 350 block will the stock pistons and crank reliably hold a compression ratio of 9:1 or more? If not what piston config. should I go with to get the best reliability? Thanks
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Stock 350 Internals
Easily. Stock compression for the 87-89 L98's is 9.3:1. It goes up to about 9.7:1 for the 90-92 L98's due to the change to flat top pistons.
Car: 88 Camaro
Engine: L98 350
Stock internals will handle about anything except NOS and +6000 rpm. If in good condition to start with you should have no problems with up to 10:1 CR with good fuel.
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
even alot of 305 engines were more than 9.0 CR
9.0 is nothin
even 9.5
nothing crazy at all
why were you thinking it might be bad ?
good luck
9.0 is nothin
even 9.5
good luck
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
The correct one to match your cam specs, cylinder design and material, vehicle usage, etc, etc.
It's not like I can say, 9.5:1 is good for you, since I have no idea what else is in the motor.
Well I have a brand new 350 short block from GMPP stock bore, stock stroke, etc. I have Edelbrock Performer RPM Intake, Edelbrock Aluminum Performer RPM Cylinder Heads (64cc), Edelbrock Hydraulic Flat Tappet Cam, Summit Aluminum Roller Rockers (1.5), and thats basically all I have right now.
Car: 1983 G20 Chevy
Transmission: 4L60
11:1 is what I ran on my Dart Iron Eagle 180 headed, production LT4 cammed 355 TBI. Keep the engine properly timed, run a good quality fuel, proper mixture, and the proper .040" quench, 93 octane, 32* total advance and ZERO detonation.
NinjaNife
Aug 23, 2015 11:49 AM
