my friend messed up my valves
Old Jun 23, 2007 | 12:34 AM
saliger64504's Avatar
Car: 1984 firebird trans am
Engine: 383 stroker
Transmission: th350
Axle/Gears: 10 bolt posi with 373 ring and pini
Hello everyone, anyone know how to set valves on a 305 with 350 heads. My friend hurd a tap comming from them and reset them. well since he messed with them i cant get the car to start he tightened everyone nute on the roker's. i had no compression in the motor after he did that so tonight i took and lossen them all up and got my compression back but it still will not fire if anyone knows a easy way for me to set my valves i would be verry appreceated of it.
thanks you
Old Jun 23, 2007 | 02:08 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: my friend messed up my valves
Look up EOIC. I just did that this afternoon, that'll work for ya.
If its tapping, you've probably wiped out your cam.
A 305 with 350 heads??
Old Jun 23, 2007 | 11:34 AM
Engine: 383 stroker
Transmission: th350
dont ask i bought the car with the 350 heads on it m and if my cam is whiped out what dose that mean mean i need a new cam put in or what the motor only has 42 miles on it but im not sure if the guy ibought the car from broke the engine in or not
Old Jun 23, 2007 | 11:39 AM
Sonix's Avatar
Car: 1982 Trans-Am
Try to reset the valves by the EOIC method. If you end up getting stuck where some of the valves won't move (stopping you from setting the one next to it), then you have wiped that lobe. And yea, that means you need a new cam.
But try setting it first, and go from there.
Old Jun 23, 2007 | 11:49 AM
Engine: 383 stroker
Transmission: th350
well if i haft to put a new cam in what would you recamend.
Old Jun 23, 2007 | 12:10 PM
Sonix's Avatar
Car: 1982 Trans-Am
Slow down, you may not need a new cam yet. Besides, I can't possibly recommend a cam without knowing ANYTHING about your engine.
I'm hoping your engine came with the 3 mounting bolts for the 163 tooth flywheel? That wouldn't effect your cam timing, no.
Ok, a quick search showed me sofakingdom explaining EOIC;
"Use the EOIC method... adjust each cylinder's intake as its exhaust just begine to open (EO), and adjust the exhaust just as the intake is fully closed (IC). Much much better than that Chilton's method. THis method will actually get them close enough to where the motor will run halfway right."
Do that first. If you notice you're rotating the engine over for a very long time, and your #6 exhaust lets say, never moves, so you can't adjust your #6 intake, then yea, you've wiped the lobe off your #6 exhaust, and you need a new cam.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
nugentcj
Camaros Wanted
Dec 22, 2015 02:58 PM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
