New starter - horrendous noise
Old Jun 24, 2007 | 02:54 PM
lakeffect2's Avatar
Car: 1993 Caprice wagon "Shammoo"
Engine: tpi'd 406, with P4 ebl EBL 730 ECM
Transmission: custom "4L65" swap.
Axle/Gears: 3.42:1 with posi
The old starter fried and was rebuilt locally. the nose of the starter was replaced. It turns over for a split second and usually makes this horrendous smashing noise. I was thinking " OK, I need to shim it out. The pinion must be slamming against the flywheel".
I used a 1/32 shim from a package of several shims. It's still making the horrendous noises. How many shims are common? How many did you have to use?
Is there something else going on?
Old Jun 24, 2007 | 08:02 PM
Chris`s85Z28's Avatar
Car: 1985 Z28
Engine: LG4 305 with a few modds
Re: New starter - horrendous noise
my guess is that you still need to shim it... add another shim and see if it makes the starter more quite
i had to do that once i ended up useing 3 shims togher.
Old Jun 24, 2007 | 09:08 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
I have used anywhere from none to almost a full pack. The one that i used alot of shims wasent a stock style starter.
If you have the room use a screwdriver to pull the starter gear out and check how it lines up. So you dont have to keep cranking it to find out.
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
