car stalling out
Car: 1990 Camaro RS
Engine: 350 TBI
car stalling out
i replaced the spark plugs, wires, distributor cap, and rotor. the car starts, but when i put the car in gear, it stalls out. before i replaced the parts, it would stall out occasionally, but only from a cold start if i didn't warm it up. but now i can't keep it from stalling out at all. any ideas???
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
Re: car stalling out
ignition timing ?
have a vacuum leak anywhere?
is the TCC stuck ?
whats your idle speed?
good luck
is the TCC stuck ?
good luck
Car: 1990 Camaro RS
Engine: 350 TBI
the idle speed is set at 1200, but when i was messin with it this morning, the brakes went out, the vaccuum on it popped off. when it was off, the car ran fine, just didn't have brakes. so i think i have a vaccuum leak somewhere.
