Weird problem while setting timing....
Old Jun 30, 2007 | 06:39 PM
IROCWPB's Avatar
Car: 88' Camaro IROC-Z
Engine: 383ci TPI
Axle/Gears: stock
I went out and bought an induction timing light and followed these instructions to set my timing:
https://www.thirdgen.org/settingtiming
I disconnected the wire coming out of the wire loom, the one with the gray connector after letting my car heat up to operating temp (160' for me). I hooked up the timing light and the timing was jumping all around while it was 'hunting' for idle, i saw that the timing was moving different ways as the rpms went up and down. I jumpered A to B on the diagnostics port under the dash and started the car back up and that did the trick, it was no longer retarding/advancing the timing. I set it to 6' advanced turned the car off and hooked everything back up and removed the wire.
Why would disconnecting that wire not work like it should?
This is the right wire, right?
Old Jun 30, 2007 | 07:09 PM
IROCWPB's Avatar
Engine: 383ci TPI
Axle/Gears: stock
Re: Weird problem while setting timing....
I don't think the timing had ever been set in my car without the computer advancing it now that i think of it, because I remember it jumping around all the time from like 4' to 8' or something like that. and now it's way retarded at idle which it never was before, it was always set as close to 6' as the guy could get it. This very well could've been my overheating problem I think.
Old Jun 30, 2007 | 09:07 PM
Damon's Avatar
That ain't the right connector to take out the computer-supplied timing. Don't know what that connector is for sure, but it's not the timing connector.
The timing connector protrudes from the main wiring loom going over top of the heater box. It's is a weatherpack connector and the wire running through it is tan with a black stripe.
Jumpering the ALDL connector will accomplish basically the same thing (at least on an F-body) for your purposes, so I think you're good to go at this point even though you were unplugging the wrong connector.
Ghettobird52
Jul 5, 2024 11:18 PM
customblackbird
Aug 15, 2021 10:16 PM
Cleotiz
Jan 6, 2018 08:56 PM
EFR2000
Aug 18, 2015 08:54 PM
sreZ28
Aug 14, 2015 07:48 PM
